Does anyone have a tip to remove the outer door handle?
Remove it from the inside after gaining access by removing the door card. It can be taken out as an assembly with the linkage to the interior handle separated at the interior handle. The final trick upon jiggling is to pull the outer handle open which gives just a bit of extra room to allow the outside part to go into the inside for removal with a bit of rotation, etc.
