1 - 10 of 10 Posts
Hello I'm trying to decide if I should put the rear axle from my 74 spider parts car into my 69 1750 berlina. The berlina has quite a bit if backlash and the rubber mount on the diff that mounts to the carrier is in bad shape. The spider looks good. Is it a direct swap? is the ratio different? Should I swap trailing arms, springs and all? The spider has yellow aftermarket springs.
Bill
The '74 Spider Has LSD (Nice) both are 4:56 . Spider springs may not work in Berlina due to the fact that the Berlina is heavier. Also the '74 has both right hand threads Lug nuts yours should have left(drivers) and right (pass) But you can change that.
· Premium Member
It'll bolt right in with the trunnion and trailing arms. Wheel stud differences are noted above (and the 2000 ones are longer to accommodate alloys), and the driveshaft bolt-holes in the pinion flange will be 9mm instead of 8mm. You can use 8mm bolts (take up the slack in the forward direction) or ream the driveshaft holes to 9mm to match. You'll need Alfa-specific bolts (9mm shaft, 13mm head); no one else will have them.
Springs vary with each model.
· Administrator
Hello I'm trying to decide if I should put the rear axle from my 74 spider parts car into my 69 1750 berlina. Should I swap trailing arms, springs and all?
The '69 was sort of an interim model - has a mix of early 105 and late 105 components. So, I am not certain whether the later trailing arms will fit.
I can tell you that for pre '69 cars, the early trailing arms have to be retained when doing a differential swap. The early trailing arms have smaller profile at the front, and the mounting pivots on the frame won't accommodate the later arms. Not sure about '69's. Compare your '69 and '74 trailing arms - if the bushings at the front are different in diameter, stick with the '69 arms. You may want to install new bushings while you have things apart.
Should I remove the axle with the T-bar? Is this easier?
This is like the question of whether the engine & transmission should be removed as a unit, or seperately. You can do it either way.
I like to remove the differential first, and then the T bar simply because I always work alone, and the combined differential and T bar is awfully heavy. Also, on reinstallation, it's kind of a pain to line up the bushings at the ends of the T bar with three bolt holes in the frame. Having the heavy diff attached will make this hard job even harder. With a lift and two strong helpers, it is probably doable.
· Premium Member
The axle will bolt to either the large or small bushing trailing arms.
Spiders had 4.10 beginning in 1982, but the axle housing as a unit is identical in terms of installation. You can bolt in any 67-on 105/115 axle in any car of those series, apart from rare Dunlop-disk axles or even rarer drum-brake early TIs.
1 - 10 of 10 Posts
