THIS IS THE OMEGA MOTORSPORT'S RACE CAR FOR SALE BY UWE BACKER.
DYNO TESTED 250 HP AT THE CRANK (193 HP AT THE REAR WHEELS), 180lb/ft TORQUE. TEST SHEET AVAILABLE BY REQUEST.
BUILT, BLUEPRINTED, AND BALANCED EURO TWIN SPARK ENGINE WITH FOLLOWING MODS:
CUSTOM HIGH COMPRESSION PISTONS, CUSTOM RODS, HIGH DURATION CAMS, BIG VALVES, STROKED AND LIGHTENED CRANK, ALUMINUM FLYWHEEL, INSTEAD OF A CHAIN CUSTOM GEAR DRIVEN LOWER TIMING INSTALLED.
PROGRAMABLE FUEL INJECTION WITH INDIVIDUAL THROTTLE BODIES AND DISTRIBUTORLESS IGNITION.
GEAR BOX:
ALL NEW LIGHTENED GEARS.
ALL NEW SYNCHROS.
4-PADS RACING CERRAMIC CLUTCH.
BRAKES:
WILWOOD CALIPERS, 4-PISTON FRONT, 2-PISTON REAR.
TILTON PEDALS AND HYDRAULICS.
SUSPENTION:
GTA SWAY BARS, FRONT AND REAR.
CUSTOM PANHARD ROD.
KONI YELLOW SHOCKS, FRONT AND REAR.
EIBACH REAR COIL-OVER SPRINGS.
POLYURETHANE BUSHINGS.
15X9 POWER TECH WHEELS.
OTHER STUFF:
CUSTOM BODY WORK.
CERRAMIC COATED HEADERS.
CUSTOM BUILT EXHAUST.
FUEL CELL WITH BUILT-IN FUEL PUMP.
FULL CUSTOM ROLL CAGE.
CUSTOM REMOTE SHIFT LINKAGE.
PLEXIGLASS REAR WINDSHIELD WITH AIR DIFFUSER.
PLEXIGLASS SIDE REAR WINDOWS WITH AIR DIFFUSERS.
DRIVER WINDOW NET WITH CUSTOM RELEASE BRACKET.
FIBERGLASS GTV RACING DASHBOARD.
FULL RACING INSTRUMENTATION.
TWO TEMPERATURE GAUGES, AT RADIATOR AND AT BACK OF THE HEAD.
ALUMINUM RADIATOR.
PRICE OF THIS MEAN TOY IS $25000, OR $15000 WITHOUT ENGINE AND GEAR BOX.
ONLY SERIOUS INQUIRES PLEASE.
CONTACT UWE BACKER AT OMEGA MOTORSPORTS (310)836-3160.
GEAR BOX:
ALL NEW SYNCHROS.
BRAKES:
SUSPENTION:
CUSTOM PANHARD ROD.
OTHER STUFF:
CUSTOM BODY WORK.
ALUMINUM RADIATOR.
