Does anyone have or know where I can get the little black looks like Bakelite bracket that secures the hood prop in place along the inner left fender line when the hood (bonnet) is closed? I understand that Alfa no longer carries that part in old stock.
Also wondering about the driver's side door jamb -- on the body, not the door -- where that little spring-loaded pointy metal piece acts to keep the door in full shut position. Mine is rounded off and needs a new one or take it apart and file it sharp again. Any ideas?
TIA,
Todd
Thanks, Andrew. I called Larry at APE and he had everything I needed - hood prop bracket, door jamb thing, and the 'wing bolt' that holds the jack in place in the trunk. Actually, mine's the wignut cuz my jack attachment place has a stud. Now, it's vacuum leak locating time. Webers have an erratic idle...
Thanks again.
Todd
