1 - 5 of 5 Posts
I just had some bodywork done on my 74 GTV. They cut and replaced the rotted metal just behind the front wheels with patch panels. The bodyshop neglected to take measurements of where the " Bertone" emblem holes were placed originally. Rather than allowing them to guess, I wondered if I could get some guidance from members for reference measurements for the hole or the emblem. Thanks a bunch in advance.
Perhaps this picture will help. My car has it's original metal so still has the holes that locate the emblem.
1675945
I can take some measurements tonight, but it is centered between the arch and the door about an inch above the rocker.
I would appreciate if you would take some measurements for emblem and the holes to locate the emblem. Thanks.
I'll do this evening. Can't do the holes, as I don't want to remove it from the freshly painted surface. I'll get you the outer dimensions though.
1 - 5 of 5 Posts
