Hi all,
More stuff I'm looking for (1973 GTV):
- Dash air vents (both sides)
- "Fasten Seat Belts" dash sign
- A pillar trims (both sides)
- Original gear shift knob
- Driver's side window cable (possibly with mechanism)
- Heater lever trim plate
- Green serpent side badges (back) and Bertone badges (front)
- Passenger's side back window gasket (or what ever holds the window in place)
- good condition (no rust) fuel tank with functional in-tank fuel pump.
Answer here or PM me.
Thanks ! :D
Hi Brian, I have some of the stuff your looking for...I also have the 3 rubber "hinges" for the rear window & gasket. Also the tank is a bottom feed and theres no fuel pump in it..
And are you looking for top vents or side vents? Thanks Jim
Hey Alfaman,
Thx for your reply.
I am looking for the side vents.
Are you saying that my 73 GTV does not have a in-tank fuel pump? I didn't know that and just assuming at this point of time (learning as I go...). But my tank is rusty enough for me to suggest a replacement.
PM me with all what you are prepared to sell and how much you want.
Thx
Brian
Update
Hi all,
OK found the A Pilars.
alfaman1963, can you PM me with how you want for the rubber "hinges" and same if you do have the side vents? Have anything else?
Brian
I've got a spare pair of side vents from a 2000 Berlina, which are the same as the GTV I'm sure. If you're interested I check their condition (I think they're near perfect), and let you know.
Message me if you're interested.
Damien
73 GTV parts - round three
Hi all,
Alfaman: do you still have rear window gasket and rubber hinges?
Damo105: still have the side vents?
Current inventory of parts I'm looking for (1973 GTV):
- Fog lights console switch (on/off - 2 wires)
- Plastic "Fasten Seat Belts" dash sign
- Original gear shift knob (I think it's black with white 1-2-3...)
- good condition fuel tank
Thanks :D
Yes I still have the air vents. They're in a box in the garage, so I'll have to dig them out to check the condition, but I'm pretty sure they're good. Postage wouldn't be much because they're pretty light.
If you are interested please send me a message.
Damien
