My Alfa lost power and cannot be re-started. The electric fuel pump is humming normally, the fuel pressure light comes on and goes out almost immediately. There does not appear to be fuel on the plugs or air intake throats after cranking a few times.
I read some earlier posts about the fuel cut off solenoid and microswitch mounted on/in the Spica pump. How can I diagnose these, and fix if there is a problem? Is there any other part of the fuel system that could cause this type of problem?
Thanks for any info you can provide!
