Wow. If you have compression, that's good. Is your spark at the right time, more or less? Is the fuel pressure light going out? There's a whole step-by-step procedure on troubleshooting the Spica system here and on Wes Ingram's site, and in Wes's book.
You can crack open one of the injector lines at the manifold to see if fuels pumps out while the engine is cranking. If so, then check the Spica pump timing. From there it starts to get more involved to determine if the Spica is working right, including checking the cold start solenoid, fuel rack spring, etc. Do some searches here, esp. in the Fuel discussion part, to see what's been listed before.
