Try cleaning everything very well with brake cleaner, adding some UV oil additive and being absolutely sure you know where its coming from. If it is the O ring then no, there is no alternative but personally I can't see it getting worse. If you do pull the head use the square section o-rings and perhaps a tiny dab of Dow Molykote to hold them in place / keep them supple.
