It's the same issues front and rear. Rubber cushions, aluminum spacers, all this comes into it.
There is some "leverage" built into the system. Put in a front spring that's 1 inch shorter, and the car will end up more than that lower, because the spring is inboard on the A arm, and the height change at the spindle is greater than that. In my experience is somewhere between 2:1 and 3:1, but my changes were not exact, probably due to interaction from side to side and front to rear, and how the weight of the car shifts as you change the ride height of each corner. You end up having to R&D the car to a small extent to get it exactly like you want.
