1 - 1 of 1 Posts
Certified Oldschooler
1. So, who has the best solution for the situation where brake fluid starts squirting out of the top of the R/L imbalance detector switch on the brake hose connector tree (that cast steel "H" dealie on the firewall with the two brake light switches). We tried a cannibalized piece and it failed also. Someone said the tapered internal slider needs new "O" ring seals. Any leads or other solutions?
2. Any leads on emergency flasher relays?
3. Who has a solution for failure of the mechanical joint on the brake vacuum line check valve (aluminum casing) that attaches to the longer bolt on the first booster. Mine appears to be leaking and affecting idle.
Thanks for your expert help and advice. Bruce
1 - 1 of 1 Posts
