1 - 20 of 45 Posts
Hello fellow Alfisi,
I bought this car 12 years ago (out of NYC via this BB), and just sat on it for the first 8 years. During those years I slowly collected the missing pieces to finish the restoration, buying NOS parts when I could and it made sense. Those 8 years were filled with distractions, restoring another GTV (my race car, "1968 GTV race car build" on the BB) and lots of racing. The last few years have been a bit topsy turvey in my line of work (oil and gas) and I had been doing less racing, so it afforded me more time to do the restoration on the '67GTV. The restoration is almost complete, so it seemed like a good time to share some photos from the job. Bad news, I lost a hard drive 3 years ago and because it was a fusion drive and apple wiped the flash portion, it was un recoverable, so I'm missing most of my photos of doing the rocker panels and floors and engine rebuild. I still have over 1,000 photos and I'll pick out some choice photos to share.
I hope everyone enjoys.
Mark
Day I picked it up, temporarily stored at my Dad's farm NE of Toronto....needed to wait until the weather was worse to haul it out West.
1620779
See...., Alberta is really nice.
1620780
Home to Calgary, Dec 31st 2008.
1620781
One of the places it was stashed while waiting... only 2 winters there. Wife didn't mind having it under the deck.
1620782
Finally some attention. 3 GTVs in a 2 car garage, snug.
1620783
Discussion Starter #2
I have photos of most stuff as I took it apart (didn't lose any of those), but no one needs to see 50 photos of a wiring harness.
here is an interesting photo show how someone in the factor hand painted some areas to black them out. That Tach got replaced with a NOS one.
1620785
I might have to take the comment about losing the engine and transmission rebuild photos;
I know people say restore the engine last, but I believe in doing it first.
The car had a 1750 in it when I bought it, but the seller had kept the original 1600. It was pulled due to a blow head gasket.
1620787
1620788
Bottom End
1620789
I'll go a little bit out of chronological order to keep the flow. I rebuilt the gearbox and Burman box while the engine was at the machine shop.
1620795
1620796
1620797
Full balanced bottom end (better than factory), new oil pump
1620798
Custom built Head stand.
1620799
always exciting/satisfying putting the head down on a rebuild.
1620805
1620806
gotta watch out for those helpers
1620807
1620808
1620809
Steering Box Rebuild- the one that came with the car was cracked. It took a bit of looking to find one that matched the car with that extra lug on the bottom of the casting. I think I've rebuilt 5 Burman boxes in total now.
1620810
1620811
Transmission rebuild photos are spotty, I did end up changing 1st, 2nd and 3 got rings, all new synchros and seal, pretty straight forward. Used a 2-5 dog ring on 1st gear to allow the upshift into 1st. Found that trick on the BB, makes going into 1st from a stop much nicer.
1620812
1620813
1620814
1620815
You might notice I'm big on re-plating fasteners, there is a very reasonable shop in Calgary, Silver Zinc, Black Zinc. $40-60 for half a shoe box...its cheaper than buying new fasteners and lots of pieces are too unique.
1620816
Two distributors to choose from...restore the one that matches the car.
Both Bosch JF4
1620822
1620823
1620824
Hi Mark,
Some times worn out parts on cars are replaced with non original parts. Years later the non original parts are assumed to be 'original'. The last owner goes off and replaces the non original part with other non original parts, thus an endless circle of miss information.
The GTV 1600 Veloce has a red line on their taco ~ 5,700 rpm. The NOS tacho you have used is for a 1300 GTJ as they have a red line at 6200 rpm.
Like you I will just have to use a 1300 GTJ tacho on my 1966 GTV out of NYC, until I find one for a GTV 1600 Veloce.
Regards Steve
Subscribed
Well, my (not infallible) memory tells me 6200rpm was always the quoted max, even though there weren’t any redlines on the tacho until the 1600 GTV. I still remember the test drivers commenting on it.
Max power Developed at 6000, redline 6200.
With the 1750s max power was at 5500, redline (again) a couple of hundred rpm higher.
2000 engines similar.
The higher 1600 redline also fits with the extra advance the 1300/1600 distributors delivered.
So...tho I take your point about substituted parts creating confusion, Steve, my dollar says the tacho in the pic is correct for the car. Here comes another one, from my March 67 GTV.
Thank you for correcting me Ranz and PSK. I must have got confused with the 1750.
So the redline is 6200 for both the GTJ 1300 and GT Veloce 1600.
Discussion Starter #13
I do appreciate the commentary about the NOS tach I used. However no one has seen what I used yet.
More progress through pictures. Into the body work...this is where I'm missing a bunch of photos
1620926
1620927
1620928
Onto the Rotisserie
1620929
1620930
Now moved into my new house- garage. Oversized triple garage, I build a booth for doing dirty work and base paints.
1620932
1620933
I did sand blast (carefully) the underside, and engine bay. All the outer panels where stripped using paint stripper and sanding.
1620944
1620945
Discussion Starter #14
More progress; I did my best to save as much of the original floor as possible, reproduction stampings are not as crisp and if the metal is good I try to leave it there.
1620990
Now I'm going to share something a bit more insane. the drivers door had been over opened (like many GTVs) and I wanted to preserve as much as possible for a few reasons. Truly good doors are nearly impossible to find, the bottom of this door was in good shape and I had a donor door that had damage near the handle. To understand how I spliced the two door frames and skins together, you have to follow the use of two aluminum templates with 1/8" holes and clicos to get the scribe line perfect. The end result couldn't have been better. The door fit with zero edge triming necessary to get correct door gaps.
Enjoy.
1620993
1620994
1620995
1620996
1620997
1620998
1620999
Important to remember which side of the scribe line to cut on.
1621001
Discussion Starter #15
Cleco holes crossed both halves before the cut, now the template holds the two halves together.
1621002
1621003
1621004
1621005
1621006
1621007
1621008
Didn't even have to open the hem on the donor shin, slipped off, no rust inside.
1621009
filled in speaker holes with more material from donor doors.
1621010
Very clever! Oh to have rust free donor parts ...
Discussion Starter #17
Free from Rust.
1621216
when sanding, I would mask off holes to keep crap from getting back in.
1621217
Lots of time spent chasing out rust where flat pieces were lapped onto each other. Weld through primer used.
1621218
1621219
1621220
1621221
Test fitting seat bolt holes.
1621222
Discussion Starter #18
I made a hammer form for this piece when I restored my '68 GTV. Now this piece is available with the usually suppliers.
1621223
1621224
1621225
1621226
1621227
1621228
1621229
Discussion Starter #20
Onto the front end, front valence and lower rad support had the standard corrosion.
I made a point of keeping the crosses on the front...because once again, reproduction panels are not crisp enough.
1621230
1621231
I'm trying to get every little curve and detail as correct as possible. Takes time, but its very satisfying.
1621232
Also doing what I can to keep the rust away for good. Etch prime, black top coat then weld thru primer.
1621233
1621234
1621235
1 - 20 of 45 Posts
