1 - 9 of 9 Posts
You should find two holes in the floor near the front of the seat. Do you have the propper chromed locating pins ?
Yes the pins are treathed with a very corse thread. As i don't own the cars any more i can not help you with pictures and such. But there must be holes in the floor if the studs have been in there. So look for a screw in the floor being there without any reason than just to close the hole. Or look for a weld. They are right in front of the seat and you can see where they should be about as you lay your mat on the floor where it should be about.
good luck.
Best regards
Rob
1 - 9 of 9 Posts
