1 - 5 of 5 Posts
Greetings;
I'm trying to assemble an early Duetto inside rear view mirror from a box of parts. There are two white pieces of plastic that control the 'dim' function. I can see how the lower piece attaches to the lever. The upper piece has a tension wire that I believe goes down into the case. It seems as if the two pieces should be connected to one another. Is that correct? Am I missing a part? Any help appreciated. Thanks, Dave
NIck- A picture is worth many words. I dug around a bit more and found the wire ring that connected the two plastic bits. That did the trick! Thanks again, Dave
1 - 5 of 5 Posts
