Every spring when I first start the car it had a fuel line leak. Third year in a row. The short line from the pressure regulator/fuel filter leaks at the regulator.
Well can you see where it's leaking? Is the hose pulling off the short brass pipe on the regulator or is that short, brass pipe loose in the regulator?
If the hose is loose on the brass pipe, are you sure the hose is the right diameter? There's two sizes of fuel line commonly available: 8 mm and 5/16" - the 5/16" line is slightly smaller, so you might try that. And sure, a longer length with a bit of a loop will be fine. And as Alfar7 suggested, the hose clamps intended for high-pressure fuel injection will grip tighter and seal better.
If the brass pipe is loos in the regulator, you can either try gluing it back in or else replace the regulator.
