Hi All,
I had this euro manifold on my 78' 2.0L spider. It worked great but necessitated the use of a block off on the bypass inlet of the 2.0L water pump. I've since switched to a later euro manifold and am selling this one.
This is the earlier manifold, which should fit 1300/1600 and larger engines. It is the style with the screw in thermostat, which I believe it dates from the early 60's. The thermostat will be included (170 degree, by my Alfa's temp gauge), as well as the top radiator hose. Also the temperature sender. Pictures below..
I'd like $130/with shipping to the US. Please PM with questions! Again - this is for the manifold, radiator hose, temperature sender, and thermostat.
