I've seen many comments on changing the gear oil in the 105 and 115 transmissions from using a small hand pump to a oil squirt can. Here's my solution. A 1/2" PVC plumbing elbow Male to female and a 1/2" male to barb. A section (3') of 1/2" ID PVC braided tubing and a small funnel. The elbow is screwed into the fill hole of the trans, The thread pitch of the elbow is very close to the threads in the trans but will not harm the trans thread when screwed in, Next screw the barb in to the female end of the elbow, attach hose to the barb and route hose up to the engine compartment and a funnel and you are good to go. I set the gear oil in the sun for an hour or so, 2 QT will slightly over fill the trans so when you remove the elbow a small amount will drip out, Replace fill plug and hopefully you put the drain plug in before filling with fresh oil. The gear oil went in as fast as I could safely pour it
