searching from the big island...conversion to 2.0l with 5 speed and need a crossmemeber and or modifications to complete the fit up in 57' 750 sprint.
tried following 2.0l conversion threads but it just goes to other subjects....
Crossmember
Hi
I'm not sure what the problem is. You need a 101 5 speed crossmember from a 63-65 Giulia Spider of Sprint. It has a square hole in the middle to fit the large 5 speed rubber mount. This is a pretty common conversion. Nothing from a 105-115 chassis will work, unless you cut and weld part of your original piece and part of the 105. Ask Larry if he has a mount from a Giulia Spider. Otherwise, I may be able to find one. It might need to be spaced down slightly because the tunnel is somewhat flatter in a 750 chassis.
KG
