hehe yep someone swapped mine to 36's too....theres a shambles going on i tells ya.. MMMM nice 44s so your saying i can have them?? hehehe only joking nice and clean though
The bigger the carb the bigger the cam and port job you'll need to get the most out of it I reckon. Are you going to install Columbo Borianni cams? I can possibly obtain the original Autodelta cam profile which you could use to have a custom set made. The Autodelta profile is designed for the 44IDFs.
a 40mm will have outright performance benefits over a 36mm only if it has larger chokes (venturies) fitted, which normally is not the case.
44's probably be the go
