The book also clearly states to synchronize the carbs you remove the blanking screws to expose the progression holes. I shine a light down one of the venturi's on each set of the carbs then, of course, adjust using the center screw. ...
I'll add here that virtually everything I've read says for someone in my position (unknowledgeable) Do Not Start Changing Jets.
Biba,
If I'm not mistaken, the progression holes are for 'bench' adjustment--not for synch'ing the carbs when running. In general, you want to stay away from the progression drillings.
I know you said you don't like using a synchrometer, but here's a very straightforward synchronizing procedure (from another source--not originally mine):
1. Make sure it's the carbs: Make sure the ignition timing is right and the spark plugs are clean and firing well.
2. Set a baseline idle: Start the engine and let it reach normal operating temperature. This may mean adjusting the idle speed as the engine warms up. Spitting back through the back of the carburettor normally indicates that the mixture is too weak, or the timing is hopelessly retarded. If this happens when the engine is warm and you know that the timing is OK, then the mixture will need trimming richer on that cylinder. Set the idle as near as you can to 900RPM.
3. Synchronize the throttle balance levers (that center screw): Using an airflow meter or carb synchroniser adjust the balance mechanism between the carbs to balance the airflow between them, if the rearmost carb is drawing less air than the front, turn the balance screw in a clockwise direction to correct this. If it is drawing more air, then turn the balance screw anti-clockwise. If the Idle speed varies at this point, adjust it back to 900 RPM, to decrease idle speed screw in an anti-clockwise direction, to increase, screw in a clockwise direction.
4. Adjust the idle mixture at each carb barrel: When you are sure that the carbs are drawing the same volume of air, visit each idle mixture screw, turn the screw counter clockwise (richening) in small increments (quarter of a turn), allowing a good 5 - 10 seconds for the engine to settle after each adjustment. Note whether engine speed increases or decreases, if it increases continue turning in that direction and checking for engine speed, then the moment that engine speed starts to fall, back off a quarter of a turn. If the engine speed goes well over 1000RPM, then trim it down using the idle speed screw, and re-adjust the idle mixture screw. If engine speed decreases then turn the mixture screw clockwise (weakening) in small increments, again if engine speed continues to rise, continue in that direction, then the moment it starts to fall, back off a quarter a turn. The mixture is correct when a quarter of a turn in either direction causes the engine speed to fall. If that barrel is spitting back then the mixture is too weak, so start turning in an anti-clockwise direction to richen. During this procedure, the idle speed may become unacceptably high, so re-adjust it and repeat the procedure for each carb barrel.
5. Double-check the idle: After all the mixture screws have been set, the idle should be fairly even; if the engine is pulsing, spitting or hunting then the mixture screws will need further adjustment. If the engine is rocking or shaking then the balance is out, so revisit with the airflow meter/ carb synchroniser and repeat the procedure from there.
This procedure worked well for me--it really is a very straightforward process. (I also changed the jetting, but
not before making sure that the carbs were properly synch'ed.)
One further thing, although it also sounds like your jetting is indeed pretty "standard", I do notice one potential problem that could be masquerading as a float level problem. The fuel in the main wells is affected not only by the float level, but by the 'displacement' of the emulsion tubes. You're running F9 tubes, which have a diameter of 8.2mm. For a 2000 cc engine, the "standard" settings suggest you should be running F2 tubes; they have
exactly the same air drillings as the F9, but they have a diameter of only 7.5mm, so there will be more fuel in the well (less fuel displaced by the tube). This will, of course, only affect the running over about 2800rpm (I know you said your stumbling was around 2200rpm), but it's probably worth changing the tubes to F2s.
Good luck.
