Hello all, I've started a rebuild of a set of 40 dcoe 80,81 carbs which I've never used.
It has obviously been opened before (screwdriver damaged jet).
I noticed the #80 carb had the old style idle mix screws (wide taper) but the #81 carb had the newer narrow taper screws.
Are these idle mix screws interchangeable with the carbs or specific to carb models? They're different length but with the same thread. Any help is greatly appreciated, thank you
