Nope, didn't say that I pushed the button. The light/switch is sitting right next to me. However it has no red push button, so I can't check it. I should remember this but believe some 69's came in without the light/switch and all of the others had a non functioning switch which I just stuck in the hole to fill it.
A friend of mine talked about this switch on his Series II Spider as being a pain in that the button would pop out and start the flashers. That is where I picked that up. It is not shown on the wiring diagram. Also I use a nice drawing (with all controls and gauges marked) of a 1750 European Spider's dash to be sure to get things back where they belong. Of course it is lacking in this switch as well as the 4-way toggle switch.
Truth be, I have another use for the hole and wanted to make sure I'm not removing something important. Current client wants a fairly involved Audio system - modern head unit, iPod connection, CD changer, separate amp, and electric antenna - all to be installed in the trunk. I found a really neat rocker switch which looks very similar to the warning switch light and uses the same size hole as on the dash. It is red and lighted when on. The face of the button is offset so it can be pushed up to turn on. It will be the master switch for all of the audio components. Okay, not quite original equipment, but unless you peek in the trunk, the interior will look pretty original.
Thanks for clairfying what the switch is actually for.
Biba
