1 - 9 of 9 Posts
Hi everybody,
I have a pair of 4 cylinder camshafts in my garage in Alfa Romeo Ricambi Originali boxes. The part number on the boxes is 060702056. The exhaust cam is stamped 2056 and the intake has a stamp 1054805, or maybe -03.
Can anyone identify these cams? I don't have an Alfa parts book anymore.
Thanks -
Richard Jemison
The 0607 cam is unknown to me. The 1054803 is a Euro application cam. If the number sequence ends in -----01 it is a 10mm lift street intake. If it ends (unlikely) in ----51 it is a 11mm lift performance cam.
Hi Richard, good to hear from you. I used to race a 71 GTV with SVRA; bought a close ratio gearbox from you some 15 years ago.
The intake cam is clearly marked 1054803. The exhaust only has 2056. However, the lifts on both are identical and I'm sure I acquired them as a pair. Interestingly, the boxes they came in also look different, suggesting different ages. Do I remember right that Fiat changed the parts numbering system when they took over? If that's the case, maybe the exhaust cam was manufactured at a later time.
they are the same cam, only with diferent part numbers, the 105.48 one is alfa part number, while the 607...... one is fiat part number both beeing the same cam, 10.0 mm lift street cam
Many thanks. I thought that might be it. So these cams I have are a pair, intake and exhaust, effectively new old stock.
Isn't the 10548 cam a 10.1 lift? Where did you find the 060702056 number,in microfiche?Regards,Phil
1 - 9 of 9 Posts
