the most common thing that happens to the 33 indicator cancelling mechanism, is the two little nylon pins on the back of the wheel boss snap off, the mechanism remains fine. If you remove the wheel, file down the snapped bits, drill two small holes and epoxy in some roll pins of the right size and length, you will never have the problem again.
