3 liter milano verde engine parts.
2405 Views 34 Replies 8 Participants Last post by  75evo
3
Stripped the block down today. All parts r 4 sale. Heads will be stripped down next week. Good water pump and tensioner installed not long before engine was removed. pistons, sleeves and rod sets available seperatele, Crank, oil pump, fly wheel bolt set a c compressor, lower and upper oil pan availabe.
Stripped 3 liter block will be availabe when done taking it apart.
1 - 20 of 35 Posts
Engine parts
How much for the complete oil pan and the flywheel bolts?
40 plus shipping
40 plus shipping
spiderrey,
I'll take the pan and bolts. Shoot me your email and I'll pay you for them. I'm going to see if I can have somebody pick them up so we don't have to mess with shipping if that is ok.
Wes,
Tell me about that exhaust tip thingy. What's the diameter of the inlet tube? Clamp-on? Weld-on? $$
TIA,
Ron
5
Alfa guy, is there anything else you need since u dont need to hassel with shipping?
Rongineer,
inlet 2 1/4, can be clamped or welded, its set up for clamping to work. Outlet 2 5/8, about 10 5/8 long.
Rongineer, pm sent back with pricing..
flywheel bolt set.
I dont know how to PM but if you call me at 337 660-3710 I would like to buy the flywheel bolt set from you if the fit the 3L 164L automatic engine. Thx
Sorry, I dont think they will fit. And Alfa guy has offered to buy they already, just waiting for payment. Thanx Reyy
Rongonerr, payment received, exhaust tip will ship today.
The other guy, fuel rail sold a while ago, sorry.
Hey, Alfaguy if you dont mind, give me a call 909 728 5500
Rey: I'm interested in the 3.0 cylinder heads.Are they complete(cams,cam caps,pushrods,etc)? Please send me a PM with info and pricing. Thanks!
You could have the heads for 75.00. They are complete as removed from the block. Just need to add shipping. it aint cheap.
call
I'll call you in the morning.
Do you have the oil pump drive gear assembly? Front cover? Flywheel? Crankshaft pulley?
Greg
Front cover right above pan, yes crank pully, yes. Fly wheel , no. Oil pump drive gear assembly, explain.
Rey:$75 plus shipping is fine with me.My address is Jim Tyson 2323 Richton St Houston,TX 77098.Let me know total cost,payment instructions,your address,etc. THANKS
I meant the pulley, shaft and gear which mounts in the head. I also need an oil pump and the dipstick and tube.
PM me pricing and availability.
I also have the shaft, dipstick, tube,oil pump, Ill see if I can figure out the gear.
1 - 20 of 35 Posts
