the distributor for my 1987 milano 3.0 is part number 0 237 322 001.
1) I opened it and found no flyweights or springs inside! Is this normal or they are somehow missing???
2) Does anybody have or know where to find the advance curve for this distributor/engine?
the problem is that at WOT the car won't pass 4500rpm, but if i let go of the throtle just a smll bit, it continues to the red line (very badly, faulty & almost without power), like if the air flow meter would be touching outside the strip. But the AFM is OK, so I was told to check on the advance/distributor. When I opened it, I found no flyweights nor springs inside (actually there was a small loose spring rolling freely inside ¿?¿??) .
Is this normal on this distributor system?
thanks
chris
thanks
chris
