I, in near future, I will be changing the timing belt and water pump on my Verde. While I'm at it, I would like to change a slightly leaky front crank seal. I have the Alfa tool for locking the flywheel to the bell housing. Does anybody have any good advice for me? Thanks!
If you have trouble with the big nut for the front crank (do you have the socket yet?), use the starter to loosen it up, but take the flywheel lock off first.:D
Not too bad to do, are you planning on replacing the cam seals and o-rings while you have the t-belt off? There are some special tools for taking the cam gears off the cams to get ot the seals, if you have them it is a pretty easy job.
I can check when I get home, I am sure someone has the metric and standard size posted somewhere on here...
Moderator
41mm aka 1 5/8" socket
If you dont have to change it, dont. The problem is that you are supposed to remove the engine and remove the upper oil pan, then take the front cover off and swap the seals, and put it all back together again. I replaced the seal on mine (without pulling the engine), and the front cover leaked quite a bit around the bottom and still got the timing belt oily.
