I stlll have the two (2, same as you) eEuroparts fluid-filled Saab mounts I ordered last spring. I still hope to cut them down by belt-sanding off the threads and getting a die to re-thread. But boring out the mount is certainly an option. I even have an A/C bracket free from another car for boring out. But I don't like doing irreversible things unless I know they're Good Irreversible Things.
I'd have tried out a 12mm drill to get a nearly zero clearance hole. I've read that the 10mm stud takes an 11mm clearance hole, so the 12mm would have added only a mm to the hole diameter. Upon need to go back to the AR mount (for any reason) I thought a sleeve would be workable.
JI'll be looking forward to hearing about your experience with this mount and its longevity. One of our south of the equator compadres was also in possession and pending on this issue.
(Great pics, by they way. And your heater core writeup was a big help for me earlier in the week.)
Michael
Michael
