1 - 12 of 12 Posts
While "operation save a sprint " has proceeded at pace my 2600 spider has sat patiently in the garage with a leaking water pump sustained during the run to Spa in June last year - so nearly 12 months off the road !
I got back to the Spider in mid May and fitted my NOS water pump , but when I restarted the engine the water pump seal died of shock - after more than 40 years idle. So then I had two leaking pumps.
Fortunately I have found SP pumps SP Water Pumps - engine water pumps for all makes and models who did an excellent job of refurbishing the pumps ( as photos).
Std price is £55 approx $ 88.
PLEASE NOTE THIS ASSUMES THE PUMP SHAFT IS OK IF YOU ARE NOT SURE YOU WILL HAVE TO BUY A NEW SHAFT AS PART OF A REPAIR KIT AS SP DONOT STOCK THIS APPROX £175 FROM CLASSIC ALFA OR SIMILAR
For this you get cleaned and painted pump , refaced surface, new water seal,gasket and new bearings.
For an additional £10 on my original pump they fitted a new impeller. The old one had mysteriously lost all its fins , which probaly explains why the engine heated up quickly when idling.
I fitted one pump the morning before the last Auto-Italia day at Stanford hall and the car completed a 180 mile round trip without any problems.
I actually had already spent over £55 on two new seals and a gasket from one of the normal German suppliers. The water seals were rejected by SP pumps as better than OEM , but not as good as their items ( which cost pennies,cents) which had a better quality and self adjusting to seal .
Ian
Ian
Thanks for sharing this info as I too had the same problem and took some time to get resolved.
I belive kits are available in Germany for almost 200 USD so this is a bargain
Thanks again
Andy
NY
I just received a nice 2600 water pump repair kit from [email protected] for 230.00 euro plus shipping .... now I just need to find some reassembly instructions.
ha ha ...
BTW, it took two weeks to get here from Italy.
Richard Jemison
Rebuilder
You best call/PM Gordon Raymond on the BB. He is the expert on rebuilding water pumps!! Probably has parts as well.
Rj
Just to show how prices change - I've had a quote from SP (Redmerlin above) - now 154 GBP!
If it helps the water pump SP rebuilt for me 9 years ago , is still working fine.
I saw that - just commenting on the price now. Mine seems ok thankfully
Ok but don't do too many laps at SPA , that's where mine died after 10 years of not doing a lot
Hi All,
send my old 2000 touring spider waterpump to SP for rebuilt .
after 500KM I did need New rebuilt...………..
rgds Franco
Is the water pump you are selling also rebuilt by SP , or one of yours by any chance?
1 - 12 of 12 Posts
