1 - 14 of 14 Posts
Here a very bad repair 2600 TS.
Severe Accident Repair Years ago without re-Forming the Body Structure.
Structure warped by about 3 cm and "Specialists" dilettantely Welded so in.
Interesting what Ideas have the People
I have Restoration in my History 12 AR 2000/2600 Touring-Spider and Zagato.
This Project is a special Higlight.
Another "bodywork expert" has previously started with restoration.
Good to see pictures of the unprofessional work and the rape of the bodywork.
Inside the beam simply welded in tubes for reinforcement.
Other people already years ago very badly delettantisch repaired stem left then cut and stopped the work.
No wonder. Up to 4 centimetres the complete stem moved. Unbelievable.
Challenge to start the whole mess from scratch to get a perfect body back on the road.
Translated with www.DeepL.com/Translator (free version)
Bernhard, thanks to your skills and experience, you might be the only person capable of bringing this car back to close to its original state.
It's obvious that whoever worked on this car has no understanding of the structural aspects of the inner rocker panel construction and the lateral sections in the engine compartment.
What's the chassis number of this car?
Hi Ruedi, many thanks.
Your opinion as THE expert makes me especially glad, of course.
Yes, this 2600 TS is very special.
Not a routine job.
Ruedi, we know each other very well and I'm sure you understand that I don't publish VIN and names here on AlfaBB.
Also not all projects ;-)
Something else Ruedi, there are certainly other experts who can know this body professionally.
I know some good professionals who also do very good jobs. Even if I have over 30 years of experience, I keep learning new things. also from other people.
Wunderbares arbeit von die ersten ”spezialisten”, kann nur besser werden.
Did you make that inner chassis rail (that is not the right name, engine bay piece?) ?
Even if you didn't awesome job!
Discussion Starter #13
main part left inside I had as used parts in stock in the barn.
outside new original old stock fenders and front mask.
other sheet metal inside parts all made new myself.
engine hood is same was the another so bad repair from Dilettantes
so I build a new one.
Discussion Starter #14
here the next step the side liners
i make all the sheets by myself.
higher material density higher strength.
also 1.5-2.00 millimeter.
galvanized sheets and additionally coated with high quality anti-rust primer.
1 - 14 of 14 Posts
