1 - 9 of 9 Posts
Hi all.
I have fitted a new headgasket after the two part gasket failed,I fitted a one piece gasket and am now getting oil leaking out at two places on the same side,it is not a weep but a trickle.
I originaly had the head presure tested and skimmed,the linners did not move,I did everything by the book and just do not know where to go from here.The only thing I had thought was the head being skimmed,would the head studs need to be shortend as they have dome nuts? any ideas. thanks chris
Hi Herve sorry about delay in replying,but have been waiting for a copy of data disc to show parts,I think you know what Im going to say,"what o rings" I did not see any when removing the head and have checked head gasket package and can not find any,I have also looked on heinbrand site at exploded diagram of head parts and cant see anything there,has anyone got a picture of these o rings? I would be greatfull.thanks chris
Push hard and live
2600 Head gasket O rings
From the 2600 parts manual
thanks to those who replied.
have just ordered new head gasket and want to know if theres any other seals I need I mentioned before the Alfa book does not show or mention the O rings,so am I missing something else? If this does not sort the problem I will send it to specialist. thanks chris
head fitting
Chris
I have done this job twice succesfully in the last 2 years on a 2600 ( two different cars !)
This should be all you need - I have previously owned later 105 series cars and 0 rings are standard fitting on these
You may want to get a later manual for the 105 series which will show the installation , the principle is the same now on a 106 2600.
I bought my O rings from classicalfa they seem to be the same on all cars . You get packs of 6 for a 4 cylinder ( I think) , you'll need 2 packs for a 2600, 8 required.
You should have roll pins in place if not classicalfa should be able to supply - I understand they just push fit ( or tap with a hammer)
Add a bit of grease to stop the 0 rings moving , they should be a tight fit anyway in the head gasket. Fit the head once , I.e. lower it cleanly onto the 0 rings . Do not lift again as this may disturb the 0 rings.
If you have the full cardisc set for the 2600 there may be a technical bulletin on this
Give me a call 07725 062339 or send photos to discuss to [email protected] if you have any further questions
cheers
Ian
thanks Ian
gasket just arrived from OKP,will refit monday and post results,hopefully good results.
Data disc also just turned up via ebay,and can now see the O rings,these things are sent to try us.also next week I am refitting reconditioned engine and gearbox to my xk150,still thats another story! cheers chris
Hi to all.
well the engine is now running and dare I say it NO LEAKS! the engine sounds nice with no tapping from cams, the new valves and guides seem to to have done the job,now just have to sort out the solid brakes and get it back out there.Thanks again chris
1 - 9 of 9 Posts
