Engine block with refitted crankshaft new bearings $ 700.00 OBO
Head compete with Cams ( with but not installed new IN Ex
valves and seats $ 700.00 OBO
Front timing cover $ 75.00
Crank shaft with new bearings $ 250.00 OBO
Valve cover with new gasket $ 125.00
My project is in the finishing stages. Part I accumulated for the build
and didn't use so off they go to help some one finish there project
All prices negotiable freight on buyer
block and front timing cover
If not sold yet these should be sold a pair as they are matched and doweled. Ask me how I know!
On my last engine build I found a NOS block and gave it with a timing cover to the engine builder
Comments from engine builder
"Regarding problems in fitting parts together, the first one was that the new block did not have a matching front cover. That supplied was not correctly lined up, being short top and bottom by about 5 thou and the timing gear bosses were about 1mm out of line. This required some clever machining to the boss in the block and an offset bush, plus milling the top face to match which resulted in having to machine the top face of six liners to produce the required 2.5 thou of protrusion. The next problem was that the front cover was Mk2 with no oil pressure relief valve and the new old stock pump was Mk1 without one either. Fortunately I spotted this and a Mk2 pump was found and the best bits of two made into one. "
This gentlemen is a real engine builder who has worked on alfa engines for over 30 years . I i had just assembled it as supplied it would not have run for long
Piotr
I have a set of crankshaft bearings caps in an old block . Send me a pm and we can work out a price , save breaking up a complete engine
