2600 Series Battaini jack. Brass/bronze gears excellent condition. As compared to a standard jack in the last photo the 2600 jack has a larger diameter shaft and the flag that holds the pivot arm is much bigger. $350.00
It is a heavy duty version of the one's found in the 4 cylinders 750,101,105 series. It is weighs more and has a larger diameter shaft, larger flag shaped arm. By picking it up you will notice it is much heavier than all my other jacks. I also found a photo of a 2600 jack to compare it to.
