Hi there you 24V owners,
I have just changed my QV (S) belt after 60kms and 5 years since the last change. The old belt was showing quite a few small cracks starting on the outer surface, and the rubber was going hard. One crack was almost 5 mm long and right through the belt material! So it seems that 5 years is a maximum time between changes, and 60 kms the absolute upper limit. So that 50 kms change time recommendation is a good one, and I feel that the time factor also essential. Do not go beyond 5 years even if the mileage is lower.
Also did the idlers, but the water pump still OK.
As for plug coils sparking away, I smear RTV sealant all over the bottom surfaces of the coils. It works OK and makes the idle nice and smooth. I clean the bottom surface thoroughly with electrical contact cleaner first of all, and those hairline cracks show up well.
Ciao,
1994QV red.
1994 Super black.
Alex.
Ciao,
1994QV red.
1994 Super black.
Alex.
