1 - 1 of 1 Posts
Hello all,
I have a 2003 Alfa 156 2.0l JTS, I took it for a cambelt change recently. Since then I’ve noticed the following, does anyone have any ideas on what it might be? It was fine before the cambelt was changed.
- down on power
- reluctant to rev
- seems rougher, less Alfa like
- lower engine note, less ‘zingy’/sporty. Used to sing round the rev counter and was turbine smooth, not now- facia trim vibrates at 4K+ rpm
- I’ve had it 15 years so have noticed the above change for the worse, it’s much less “Alfa-like”
And now:
- fuel economy is off
- engine fault light (yellow) (go to dealer etc) has just come on; stutters occasionally
Has not done many mkiles since the cambelt change.
Might it be-
- variator?
- crankshaft timing sensor?
- other?
Any suggestions/things to check would be gratefully received
1 - 1 of 1 Posts
