1 - 1 of 1 Posts
1 st .question... on the castor bushings.. if i change mine to poly.. will it cause any damage to the castor arm next to the headlamp area.:(:eek:.my thoughts are the poly is harder, and this might cause the mount next to the headlight to fail.:eek:. and if i do put them in can the be instaled without taking aprt the front suspension?.:cool:...2 nd. question.. rear sway bar... who here has disconected the rear sway bar to improve the handleing?.. my thoughts agian....you normaly set the rear suspsension to be soft.. so my rear shocks are at full soft and my rear spring rates are 125#.. but my wheels and tires are 205/50/16.. so the sidewalls fo my tires are a bit stiff,:eek: do to the diameter and profile, i run them at 32 psi. if the road gets wet in a turn i tend to rotate a bit more then i want:(( can be fun :D, but not on crowded roads).. thanks for any help..:)
1 - 1 of 1 Posts
