With engine running, 0 volts at fuel vapor recovery solenoid. If I apply voltage by jumping solenoid it makes a noise, but not a click and I still cannot blow air through it. I was thinking of replacing solenoid but maybe I have another problem, or maybe the solenoid is only powered intermittently.
13v at windshield washer, which I don't really need but my ocd makes me want to get it to work. Pump doesn't run. If I use jumper wires, 13v makes pump run. I tried a different ground and bypassing plug, but still no good. I'm thinking not enough current through switch/wire but my meter only goes up to 5 amps. Any ideas?
Thank you
Thank you
