41 - 52 of 52 Posts
Hi I'm looking to go the injection route as well can you tell me where you ordered the ITB's from
many thanks
Located in Australia.
Discussion Starter #43
Hi I looked back at the order on eBay but they don't have the 40mm version only 45mm all your looking for are the ones with DCOE style in the description so they fit the space and the throttle linkage matches
Similar item here, I have no links to this shop if I'm braking any site rules let me know and il remove the link
Look at this on eBay
Discussion Starter #46
Another part just arrived, I'm not so confident to weld an O2 boss in my new stainless header, this just requires a hole drilled
1623697
I have seen them used before and they seem to be quite good. I am not sure how they will last in the long run though.
Can I ask how are getting the crank trigger signal for the ECU ?
Discussion Starter #48
I guess I can always get a boss welded in later if it fails but it seems to be a strong construction. For the trigger wheel I fitted a trigger wheel behind the front pulley and extended the front casing bolts to mount a sensor bracket
1623944
1623945
1623946
Discussion Starter #51
New brain fitted
1629878
And with hinged plate dropped down for access
1629881
I made a tubular frame that picked up on the glovebox mounts, it stiffens up the dash around the glove box hinges and supports the weight of the ECU and relays
Discussion Starter #52
Slowly getting there, fuel system now installed and secondary circuit tested, used a weld free insert for the fuel line return to tank
1631621
Just drill a 20mm hole (after draining tank and filling with water)
tighten the bolt whilst holding the insert and it rivets itself like a nutsert compressing the rubber gasket
1631623
then just a matter of bolting it all in and connecting the hoses
1631624
once I’m sure nothing is leaking I will make a cover to protect the hoses and pump
41 - 52 of 52 Posts
