1 - 20 of 38 Posts
It’s always been the plan to fit ITB’s and fuel injection so now the engine rebuild is near the end I’m starting with the adaption
Trigger wheel fitted to back of pulley, this needed a flat machining on the back leaving a shallow step to locate the trigger wheel which needed machining to match.
I used stainless stud extenders on two of the timing chain cover bolts to mount the crank sensor bracket, all of this can be reversed back to original which is always my plan where possible
Subscribe
Nice!
I'm starting down the same path. What sensor are you using and are you going to use a wasted spark setup, or are you also going to have a cam position sensor?
I haven't decided whether to use an Omex, MegaSquirt or Microsquirt controller. What are you planning on?
My plan is to go with Emerald (UK firm) for the ecu as they offer a pre programmed ECU and remote access to laptop, I know it’s more money but the electrics are where I’m weak so don’t feel confident with Mega Squirt option
Sensor came from trigger wheels.com a good site for most of the things you will need, I have drilled and tapped the intake manifold just behind the thermostat for the water temp and the filter back plate will be drilled for the air temp sensor, throttle pot came with the ITB’s
Next job is to run a new high pressure fuel line and fit a small tank with fuel pump fitted , I’m making a 12mm spacer ring to fit between fuel sender and tank, the two return fuel lines will fit into this
I will update with photos when I have something worth showing, I’m sure I will be asking a few questions along the way
Emerald is a good choice. Have you seen that website where the guy builds an open wheel car with an Alfa V-6? It's a pretty comprehensive write-up and I think he uses an Emerald ECU. http://www.alfadax.com/
What sort of ITB's are you using? I'm thinking about using the SPICA ITB's or maybe a set of throttle bodies from a suzuki GSXR.
I've been working with a SPICA manifold, and if I use the SPICA ITBs, I'll use the original fuel injector ports modified to fit modern electronic fuel injectors.
triggerwheels.com is great. I got mine there and I thought yours looked familiar!
I bought the TB’s from a shop on eBay they were a good price and now I have my hands on them I’m happy with quality , I have a Spica manifold and bodies they need special long nose injectors to get the end of the nozzle just in the manifold and not easy to fit bellmouths but if your trying to look as stock as possible it’s the way to go, if money is not a concern the Webber DCOE injection is the simplest solution it replaces the carbs with something that looks identical but the injectors are under the top cover so looks completely stock
I have an Emerald with my Twin Spark and Spica throttles. I like the interface and it was not too difficult to wire. When you tell them what engine you are using, not only do they send you a base map, but they send you a wiring table. They will also answer your troubleshooting emails. I am very satisfied with Emerald and their support.
For some reason, it seems to be a widely held choice when using throttle bodies. The maps come standard with the rpm vs throttle position. There is a MAP compensation table, but I haven't been able to figure that out yet. I'm just using rpm vs tps. My MAP signal is not very stable even though I've done everything I've learned about damping the vacuum pulses.
If not using throttle bodies, or if your MAP signal is good, you can change the vertical axis to MAP. It is not obvious, it's kind of hidden in the settings somewhere.
I can relay my gotchas when you are ready to start up. Good luck with build and post lots of pictures.
Stefano,
How did you attach the Spica throttle bodies to the Twin Spark head?
I haven't made up my mind whether to use Spica throttle bodies or something else.
Discussion Starter #10 (Edited)
Did you fit a lambda sensor? If yes narrow or wide band?
Dave walker who owns emerald used to write a feature in Car and Car Conversion back in the 90’s he was one of the few who could add EFI to cars never intended to have it, used to convert DCOE to throttle bodies etc before that emerald were cam builders so they know what they are doing
I used one of Jim Steck's tricks. He welds them to the TS intake manifold.
The SPICA ITBs look like they are bolted onto the manifold, so I'm wondering what exactly do you weld to the manifold?
Did you cut up the original SPICA manifold and weld the portion of it with the SPICA ITB bolt pattern to the manifold?
I could have elaborated more. Sorry. I didn't want to deviate too much from the original thread about a Nord EFI. You send him your TS manifold and a Spica manifold. He makes a flange that matches the Spica throttle bodies and welds that to the TS manifold. Then he can bolt the Spica throttle bodies to the plate. He welds a plate for a TPS on the front of the front throttle body. He takes any vacuum ports on your Spica manifold and transfers them over to the TS manifold; brake vacuum etc. He also welds your bell crank to the fuel rail. Everything is intact and you can adjust your throttle cable and throttle bodies exactly the same way as outlined in the Spica adjustment routine.
Yes, I used a wideband so I could take advantage of the adaptive learning part. Very nice. I used a PLX controller. If you want to do that, take a look at what others have chosen. There was a little problem with the LC controller and Emerald. Maybe he sorted that out by now, though. But pay attention to what brand you decide.
Dave Walker is awesome. He is engaged with you and really know ITBs. Seems to have done most of his work with small 4 cylinders like Caterhams and little Fords. I asked several other engine management suppliers about the twin spark and most of them were unaware of the Alfa TS. It sparks twice simultaneously where as others do a wasted spark. So they all ask if it is wasted spark. I say no and they start fumbling with their words. Seems it takes them by surprise. Dave Walker said "Twin Spark from an Alfa 75? Sure we know that. It'll work. Just select 'Simultaneous Spark' in the ignition settings".
My words here, but you will see the picture has it in the back of the back pair. This picture was from his website. Mine is on the front. I can't remember if he asked me where I wanted it or if he just puts it on the front now. It's been many years now.
I would also recommend Dave's book on Engine Management (published by Haynes). It's very insightful and covers a lot on carbs and cams as well as EFI content.
I'm in South Bucks and have an Emerald on my Caterham if you need any help/tips. The user interface is very simple if you need to tweak any maps. I presume Dave/Karl preloaded the ECU with something they believe will let you start the engine?
Depending upon where you are in Bucks, I can also recommend Northampton motorsport for mapping, or DK engineering, if you are in South Bucks (and want to take a tour of some very expensive metal whilst you're there!)
Discussion Starter #19
Getting closer, throttle bodies fitted and linkage fitted up, think I need to clean up a little
1600 engine is ready to come out
Swap gearbox, starter and sensors
Engine bay needs some rust taking care of whilst it’s easy to access then it’s fit the new fuel lines and install the new engine
1 - 20 of 38 Posts
