Have some issues with the car I purchased this past spring, please advise if you can help or suggest where to get parts required . The previous owner was obviously having problems
and has been messing with some of the wiring, much of which we have been able to return to new.
speedo and tachometer not working: mechanic says I may need the entire cluster ( where can I get this) or just the tachometer if that can be purchased separately .
AC cycle switch grounded: mechanic says he believes the 4pin ( on/off?) AC cycle switch is grounded but not 100% sure. one of the 4 pins is grounded and he's not sure if that is
normal or failure of the switch.
Any help appreciated.
