No accidents. In 1994 it was hit by a golf ball below the driver's window and the repair is perfect. Otherwise, there is a ding in the right fender which I just photographed and may be visible The nose, which Alfas get dinged, seems fine and I took a pic also just now. I'd say the paint is very good although I haven't had it waxed in years. It has been garaged 90% and never been in snow and rarely in rain. AC and odometer do not operate. Also: often going over a pothole, the airbag light would be set off and it was a pain to take it in to have it reset, so that wire was disconnected some years ago. I assume the airbag electronics work ok although the bag itself is 21 years old so I wouldn't count on the airbag working anyway. Also, I ditched the electric motor for the radio antenna in 1994 and installed a standard manual antenna. In fact there were a few warranty repairs in 1990 and 1991 to the electrical system like this.
In addition to minor services and yearly oil and filter changes:
Sept 08: pass side window motor
Sept 07: rear trans mount, flex joint and U joint in transmission
Aug 07: clutch pivot pin, clutch hose, slave cylinder rebuild
Aug 06: trans flush, clutch flush
Aug 05: cooling fan replace, tie rods replace, front align, replace coolant recovery bottle, turn signal flasher (this shorts when you go through the carwash I found out the hard way)
June 03: motor mounts, U joint and flex joint (must not have done it right since they were changed, apparently in 07 also)
Aug 01: spark plugs, ignition wires, valve cover gasket, air intake boot, belt, caster bushing, tied rod end
Aug 99: muffler
Oct 95: U joint, shift boot replacement
various: trunk release cable replaced, twice
Jan 95: air filter, fuel filter, valve cover gasket, belt
Oct 94: brake pads, window motor
Mar 94: convertible top
Also: 11 years or more ago, there was a sound from one of the exhaust manifolds and it was a pinhole so that a manifold had to be replaced, see items 14252 and 14253 at International Auto Parts
Welcome to International Auto Parts. I have the "top boot" see item 30388 in the original tan color although I have not put it on the car in many years and the snaps may be not all there etc.
