1 - 2 of 2 Posts
I noticed today my temp gauge read over 175 while at idle and the radiator cooling fans did not turn on.
Traced it down to a missing relay in the fuse box.
I think the relay might have been plugged into the wrong spot, because I moved one relay over 2 slots into the cooling fan slot and the fans kick on normally now.
I cannot figure out what the slot I moved the relay from controls.
Everything in the car seems to work.
Does anyone have a detailed diagram of the fuse box with relays.
thanks
here is the relay set up and fuse ratings.
From your description it sounds like you used the relay from the "rear demister" slot (if you had a hardtop)
The fan relay is a fused relay, like photo.
The demister relay would be a normal sipea 0440.
1 - 2 of 2 Posts
