1 - 20 of 21 Posts
I recently bought a pre-stripped 91 164L AT for the working engine. I have gotten the engine out and want to offer some parts for sale. I can ship the smaller items, but larger items will be pick up only. The engine itself (and the wiring/computer) are not for sale. The parts are located in Olney, Maryland.
-Brake Fluid reservoir - (cap/sensor included) $30 shipped
-Windshield washer reservoir - $40 shipped (no cracks, working pump included, no cap)
Discussion Starter #2
Of course, if I didnt mention something and its in the engine bay let me know. Pictures work well, of the part you may need.
My pictures will be coming in a day or two. Thanks!
I'm interested in the power steering preasure hose if its the early style with a 'banjo' fitting at the pump. Even if its in bad shape, I can have it remanufactured.
I'm interested in the power steering preasure hose if its the early style with a 'banjo' fitting at the pump. Even if its in bad shape, I can have it remaunfactured.
Yep, I have that hose and its got a banjo fitting. Pictures coming by the end of the week of all of the parts.
Okay. Let's finish the sale via PM. Message sent.
Good to see you are parting it out, even more -haha! Good luck! Let me know on the parts we had discussed before via email.
Leonard
Discussion Starter #8 (Edited)
164L AT, Exhaust front section with catalytic converter and oxygen sensor. Flex sections in great shape, no leaks. $70 pickup only
Exhaust center section 164L (no leaks) - $30 pickup only
Muffler 164S (no leaks) - $40 pick up only
164 parts
Hi,
Do you have the coolant reservoir bottle, and the a/c compressor?
I also could use the exhaust/muffler, but I'm not sure where you are located. I'm in S California
Khalil
Discussion Starter #11 (Edited)
Hi,
Khalil
I'm located in the Washington D.C. Area. Shipping for the exhaust may be a bit much. I do have the ac compressor, coolant reservoir and could ship them. Thanks for looking
hi,
thanks for the quick response - pls tell me how much for the a/c compressor, coolant bottle, each so I can decide.
thanks,
Khalil
Discussion Starter #14
Coolant reservoir - $40 shipped
Airbag - $125 shipped
Power steering pump/pulley/banjo bolts - $60 shipped
Air flow meter, air filter box $ 90 shipped
Upper engine brace, with poly bushing installed - $40 shipped
Discussion Starter #15 (Edited)
Fake firewall brace, with fuel line holder - $15 shipped
I was told that the AC worked. I ran the car, but could not turn on the AC due to the controls being gone. When the system was evacuated, there was a sufficient amount of refrigerant for the system to function. The compressor did not make any noise, although it could not be engaged/turned on.
AC Evaporator, with expansion valve - $160 shipped
AC Receiver Drier, with pressure switch - $30 shipped
AC Compressor/with clutch - $80 shipped
Heater Core, no leaks - $100 shipped
Discussion Starter #16 (Edited)
Blower Fan Assembly, tested good - $90 shipped
Speedometer Cluster, 100% working condition (157,000mi)- $110 shipped
Wiper Motor, with linkage - $50 shipped
Power Steering Reservoir and cap $30 shipped. Hoses sold.
Radiator, radiator fan, coolant fan switch, shroud $200 shipped
AC epr valve
Do you have the air conditioning EPR valve. Its the valve on the right side of the inner fender connected to the A/C lines?
1 - 20 of 21 Posts
