I have just changed my water pump, fuel filter, and fuel pump. I was driving my car, and it died. I tried to start it, it runs rough, and eventually dies, even if I give it gas. It acts likes it's not getting air or fuel. I checked all of the air lines, and they're all tight. If anyone has an idea for me please let me know.
Joe
After all the work you did, I would look for a vacuum leak. Did you replace everything where it belongs? If the car was running normally prior to all the work you did- that's where I would start troubleshooting.
Duke
Check the fuel filter,make sure it is in in the right direction. Check the fuel pump wires, that they are tight and not touching anything they are not suppose to. Kinks in the fuel line where it connects and that the fuel filter is tight. An air leak there might keep the pump from drawing.
If you checked the air filter, make sure the wire is secure on the AFM.
