1 - 9 of 9 Posts
Just had my pod rebuilt 3 months ago. Everthing was working great then the speedometer and heater fan went out. So I checked the fuse and it was bad. Replaced the #9 fuse. Thought that would resolve problem. Car would not start, no nosie, no cliicking nothing. Put volt meter on battery 12.75. Took out the fuse that I just replaced ( it was not bowen). Tried to start the car again and it turned over great. I think it sounds like a short but where (fuse box). Thanks for the help
What about your relays, have you played with some of the relays maybe? Do your interior lights work, have you tried replacing this relay?
1989 spider veloce wiring problem
Have not played with any relays and the interior light still work.
Ignition switch? Pull the switch out, pull it apart, spray it down with electronics cleaner, put it back it (dry of course) and retest. You definetly have a short no doubt it, but where...
I'll look in the manuel how hard is it to pull ignition switch. Also how would #9 fuse short to ignition switch. Thanks
Maybe it doesn't short to switch, maybe the short is in between, that fuse may only light up with the key in the on position. Putting enough drain on the electrical system to not allow the car to crank.
If that is the case. Should I check the following at the starter. #1 with fuse in get reading. #2 With fuse in and key turned get reading. any other ideas
Well, what does #9 fuse feed to begin with? Heater and speedometer? Put a lower amp rated fuse in and see if it blows with the key out, then if it doesn't, turn the key on. Process of elimination. You have a short, you just want to know where and when.
attached is the tech bulleting updated fuse-assignment for the 89
1 - 9 of 9 Posts
