Hello, this is my first time posting here. Thought I might be able to find some help with my Alfa.
I have an '89 Veloce that will not start. Car has been sitting in a garage for about a year. I started with the ignition system and found that somehow the previous owner got spark plug nipples stuck up in the ignition wire terminals (corroded). I replaced the spark plugs, ignition wires, and confirmed that I have spark at each cylinder. So I am certain the ignition system is working properly.
My next guess is that I have a fuel problem. Either the fuel pump is not working, I have bad injectors...or maybe the fuel has gone bad from sitting? I added about a gallon of fresh gas to the tank last week, and it did not help.
Hoping some of you more experienced guys can point me in the right direction. Is this a common issue for many Alfa's?
Thank you,
Greg
Thank you,
Greg
