Hi- Does anyone have a procedure for replacing a broken cable on the power window. I have the shop manual but it is lacking
grazie
Lorenzo
There is a diagram of the cable routing here: Cables are too tight on the window
As I recall (knowing that my recalling ain't what it used to be...) the most difficult part was wrapping the cable around the drum and getting it to stay there. I do recall what I did was to cut a piece of plastic pipe into a 'C' shape and put that onto the drum after winding on the cable. This kept it there while I got other parts installed. Then, when I was ready, I pushed the piece of the pipe off and retrieved it from the bottom of the door.
thank you Eric - in the meantime i have found the loads of previous post related to my problem - fantastic resource !
ciao
Lorenzo
