I am reposting my Verde for sale because the previous ad veered off topic:
1988 Milano Verde
Always professionally maintained by specialists
Records going back three owners, two other alfabb members
Excellent body and mechanicals
Recovered seats
Excellent paint
$4k service in June, tbelt/wp, no leaks, no red lights, no issues at all
One of the best around
175k miles
Asking $6.5k
Car is located in Palo Alto, CA
Please email indicam3 at gmail
---Detailed description---
This Milano drives beautifully. The engine runs great, revs smooth, pulls strong and sounds great, and the trans shifts great even from cold. New stock exhaust. Drivetrain donuts and center bearing have been replaced. Every single fuel hose, vacuum hose, cooling hose, heater hose, belt, ignition wire, and fuel injector have been replaced, mostly within the last 25k miles. Every Bosch sensor was checked against spec, several were replaced with new (TTS, CTS, throttle switch, oxy sensor, AAV, maybe more). Every questionable electrical connector has been replaced with new Bosch connectors.
The interior is extremely clean, every single switch, light, button, gauge, knob, etc works fine. No dash cracks, all seats all recovered with a high quality black cloth that matches the carpets and headliner. Sunroof and windows all work fine, though the headliner cloth was removed from the sunroof section. The only rattle is from the sunroof over really bad roads. HVAC is perfect, AC blows cold. Dash was removed and heater box restored, leaves removed, leaf trap installed, resealed all joints with new foam, fixed up all the linkages, new heater valve, etc.
Steering system is perfect. Every hose has been replaced, rack and pump replaced at 160k. Koni red shocks installed at about 150k. No clunks or creaks in the suspension or steering, entire front suspension was rebuilt, all bushings, ball joints, tie rods, etc have been recently replaced. Steering feel is excellent, no slop. Tracks straight. Wheels are original in perfect shape.
ABS system perfect. Pump, pressure switch and accumulator replaced and work great. All hydraulic hoses are replaced.
Cooling system perfect. Temp gauge rock solid in all conditions.
Remote keyless entry system works great. Stereo is an alpine unit that works fine.
Thanks for looking.
Kevin
1988 Milano Verde
Recovered seats
Excellent paint
175k miles
Asking $6.5k
Thanks for looking.
Kevin
