1 - 17 of 17 Posts
For sale: 1988 Alfa Romeo Milano Verde with 106K miles. Leaks oil in all of the expected places. Dry rotted tires, tired interior, usual electrical problems. California, single owner car. Tons of fun to drive when it works. Ran when parked 10 years ago. Engine turns freely and ran roughly for a few minutes when we rolled it out of the garage yesterday to take photos. Located in San Luis Obispo CA. Motivated seller. Would like to have it hauled away this week. PM for links to more photos or additional info. $1500/offer.
replies
I just realized I can't PM. So to answer some of your questions: No accidents, just California baked paint (through the clear-coat but color coat is good.) Yes started on old gas. Just wanted to see if it would crank. We jumped it and let it run for a few minutes. Ran rough (5 cylinders) but started without any tinkering. Front seats are split, but there is two yards of Recaro fabric in the trunk. More photos at Flickr. Just go to flicker_dot_com_slash_GeorgeCo
On a plane
On a plane this morning, but will contact folks who have sent PMs later this afternoon.
Thanks George. We are going to pick it up.tomorrow and attempt to drive it home. If anyone has any suggestions for working with a Milano that has sat for a long time I'm all ears
If anyone wants to vicariously go on this adventure with @Caxny and I, im going to post to Instagram along the way. Hope.to get the initial startup on video, etc..
Instagram handle is alfaddiction. Just set it up - please follow me!
Until tomorrow....
Don't Drive it home for the love of god...........That timing belt is probably crispier than a 2 year olds diaper
I agree, if you are thinking of driving this particular car all the way to Maryland, I sure wouldn't without having the timing belt changed. You could easily end up in Nowhere, New Mexico, or wherever, with trashed valves.
Can you recommend how to inspect it? I assume the cover comes off pretty easily as it seems pretty exposed there on the front, but can you really judge condition of it visually? Also, I don't know if they tend to break at high revs or will break idling -- we definitely plan to keep the rpms low.
Discussion Starter #13
Good news (maybe) -- found some records. It last passed smog in 2016, but more importantly had timing belt replaced in 2009. Brake calipers were replaced in 2010. So it's been sitting for about 2.5 years. I'll send more details when I get the printout from the shop, I just got that over the phone.
2009! -- yeah that belt needs to be changed before it is driven anywhere.
Good luck!
Thanks George! Yes please send us all the info you can, timing belt is the biggest concern right now. If you can find out the mileage at which it was replaced and also give us the name and phone # of the shop that did the work in case we need to call them that would be outstanding.
We are in Camarillo -- hit the usual LA traffic.
Thanks - very excited!
Discussion Starter #16
repair records
Got the printouts will forward to your email. Going backwards:
2/15/16 passed smog so that's the last time I'm sure it was running. The mileage on the bill is the same as what's on the car now so I suspect the odometer stopped working.
2/4/14 Brake fluid flush/replace; replace O2 sensor; remove AC pulley (pulley seized) [I'm assuming that means disconnected the belt so no AC?]
3/8/10 Waterpump & thermostat replaced; front pads, rotors, calipers and hoses replaced; repacked front wheel bearings.
3/26/09 ABS pump replaced; low oil light and coolant level light inop. [So don't count on the lights for warnings]
2/9/09 Oil pressure unit sender replaced, rear main seal, flex disc, valve cover gasket, cam seal, F crank seal, Timing belt, tensioner and 3 drive belts replaced.
1 - 17 of 17 Posts
