My son removed his gauge cluster as part of a project to replace the dash. He took photos of everything, but given most of his experience is with Jeep and Nissan vehicles, he didn't consider any possibility that plugs might interchange.
Before taking it out, everything worked except the tach. I found a bent pin which is likely to fix that.
After installing, nothing works properly. For instance, turn the heater switch on and the rear window defroster active light comes on. There are no gauge lights.
He removed the harnesses both at the cluster and the connectors under the dash. Are these plugs actually interchangeable?
We looked at the partially correct manual, it shows connectors A-D, with no mention of which is which...
